Middle of the screen my laptop have a line like inner display scatch. whatever i do the Line like scatch shown always on the middle of the screen. it start happening begin from the pc on. now i need a quick solution to remove the problem and make again my laptop screen look like as usual better.
Not to be the person with bad news.
But it is more than likely you have at some point cracked the screen, that is the only way it can get a scratch on the inside.
If you can take to a computer repairer they will confirm if you have and will probably need to replace the screen.
Cost I am not shore but can not see it being cheap.
Regards Craig
SOURCE: Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
SOURCE: Display has lines that run through it
they can be horizontal. I think your graphics card on your motherboard is bad. you should consider sending it to acer so they can replace it with a new one.
SOURCE: Thick Black Line on Screen
This is caused by dead pixel sensors. There are hundreds of pixel sensors at the edges of the screen, when they go out it will cause a line varying in size depending on the amount of sensors that go out, and the line can vary in color, red, blue, green, white, and black. Unfortunately, the only fix for this is to replace the screen.
SOURCE: a horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
SOURCE: vertical line on screen Lenovo T61 Laptop
You have a dead column of pixels. The only solution I'm afraid is to replace the LCD screen.
I'm sorry the news isn't good but can you take a moment and rate the solution as fixya even if it wasn't what you wanted to hear? Thanks! :c)
