I've only been using my new Kanguru external dvd burner for a short time & it has been working fine, but today it won't do anything. It makes noise like it's on, but when I insert a DVD it doesn't seem to do anything. It doesn't display the dvd content at all. I've tried disc that worked fine in it yesterday, but today it doesn't display anything. I was going to try burning a disc, but there is no option to burn a disc for some reason.
SOURCE: Samsung DVD writer SH-S182 problem
try a different power connector from psu,do not share same as HD!!should work!!
SOURCE: TSSTcorp CD/DVDW SH-S182M
We have the same problem here with this Samsung DVD burner & want to know if you have found a fix for it.
[email protected]
SOURCE: super multi dvd writer gsa-h55n
Well, since I received a solution from MAXTRIXKHAN, I just wanted to check back with NCIX.com, and here is a recap of what I did, and what they told me...
After a few tries, I had to contact LG Customer service.
I tried to burn to...
-Maxell CD-R, no problems,
-TDK DVD-RW, no problems,
-Verbatim DVD+R, Computer hangs.
Well, I bought this DVD-Writer to replace my old GSA-4167B, and LG customer service told me that this DVD-Writer does not support the Verbatim DVDs.
So, if you have plenty of Verbatim DVDs, you should forget about this writer.
Supported DVDs...
Maxell, Sony, TDK
Will have to send it back to NCIX
So beware
tiyo73
SOURCE: i o magic external dvd burner wont work
most likey it is incompatlable with vista ? did you check the specks lala linda
SOURCE: i want to burn dvd using cheetah dvd burner,when i
Might be several reasons
Take a look on front panel if it says DVD-RW use only DVD-R (RW) blanks, +RW only +R(RW), +/- or RAM both. Check the record speed your blanks might have higher speed than allowed
Also blank might be upside down
Hope that helps
Good Luck
