Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
Anonymous Posted on May 13, 2013
Bosch Dishwasher using too much salt
Hi my dishwasher is using the entire salt reserve a very couple of days. Website seems to suggest a screw style adjuster or seal near the top up point but this model doesnt appear to have one. Any ideas? Thanks
Anonymous
Level 2:
  • Bosch Expert 414 Answers
  • Posted on May 30, 2013
Anonymous
Bosch Expert
Level 2:
Answers
414
Questions
0
Helped
267246
Points
941
This will be the regeneration valve sticking in the open position. It is located on the regeneration unit behind the left side panel (looking from the front). It is fairly easy and inexpensive to change....however, the cheapest fix (if you are not in an extremely hard water area) is to switch to an all in one tab and not put any salt in at all!!!
5 Related Answers
Anonymous
  • Posted on Feb 20, 2009
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Anonymous
  • 11 Answers
  • Posted on Feb 05, 2009
SOURCE: Securing Bosch SHU 4300 under "hard" countertops
If this is a new Bosch Dishwasher then there should be two metal tabs that protrude from the top of the tub above the door. These tabs are for top mounting the dishwasher to a wood countertop, however these tabs also can be relocated to side mount the dishwasher to the cabinetry. The way to do this is to pull the dishwasher out of the hole it is in, in the counter (be careful not to pull too hard or to move the machine out too far due to the length of the water and electric lines). just pull it out easy till you can see the tabs, Now using a pair of pliers, bend the tabs on the backside of the mounts straight so you can remove them from the framing of the dishwasher. Next look at the tabs there should be a perforation where you can use 2 pairs of pliers to snap the tabs off at the perforation, after snapping off these tabs, look at the sides of the dishwasher and you will see a slot where you can reattach the tabs into, and bend the tabs in the back to hold them in place. If you look at the rubber gasket material on both sides of the machine - you can see where the round holes are located for side mounting. Attach the tabs and gently push the machine back into the cabinetry. Now using a small drill bit, drill a pilot hole into both sides of the cabinets to mount the dishwasher. You want to drill these pilot holes so as not to split the counter facing when you drill in the screws. Using the Bosch screws that came with the dishwasher (or small flat phillips screws) slowly screw in the screws into the sides of the cabinetry. When you attempt to remove the machine from the cabinetry you may find that it is adjusted tight to the countertop. If this is the case you will need to remove the 2 screws that hold the kickplate in at the bottom of the dishwasher in the front and remove the kickplate. Then you will need to bring up the front legs on both the left and the right and also the rear leg which is adjusted up and down by using a flat blade screwdriver. Look at the front of the dishwasher, behind the kickplate and there will be a adjusting screw with arrows which point left to right. the direction you turn this screw will determine which way the dishwasher will adjust,- right adjusts the machine higher and left lower. Good luck!!!!!! Hope this helps.
A
Anonymous
  • Posted on Aug 21, 2008
SOURCE: Bosch HydroSensor Dishwasher (SGS5342GB/17) -
Hi Julie,
The sprayer arms may need replacing.
Anonymous
  • Posted on Oct 19, 2008
I had this same problem and in addition as it ran water dripped out the bottom while the dishwasher was running just before the tap light came out. Check the outlet hose is not blocked. Ours was blocked at the T junction where it met the sink outlet. Once the blockage was cleared we hit another problem - the pump kept trying to drain - even when the door was open. Found an excellent solution to that on this site. It had occured as the previous problem had casued the flood switch to be triggered. We had to tile the sihwasher back 45 degrees to fix it. Now its workig fine again.
Anonymous
  • Posted on Aug 06, 2009
SOURCE: dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Error code 12 on my ecomax dishwasher
According to the Bosch website, an E12 error code indicates a build-up of limescale in the heat pump. The solution is to purchase the Bosch descaler to remove hard water deposits and limescale buildup .
If you're unsure how to descale your dishwasher, Bosch provides instructions on their website . Additionally, they recommend using softening salt in your dishwasher if it comes with a water softener or utilizes it .
Oct 26, 2023 • Dishwashers
Dishwasher using up salt way too quickly
Hey Oliver,
Please check the cover has a seal and is fitted correctly on the salt dispenser. Make sure the cap is screwed on tightly ;-)
It is important to set the water hardness - the water softener should be adjusted according to the hardness of the water in your area. The factory setting is for average water hardness, you may need to change this.
Best,
Dave, Just Fixed
https://www.justfixed.co.uk/
Dec 22, 2021 • Dishwashers
1helpful
Salt is blocked and not going down
u take dishwasher pump apart and cleaned from salt using water, it seems that the pump was jammed .
5helpful
Just moved into a house with fitted NEFF dishwasher, never had one before and no manual left. Where do salts go? Thanks
The salt goes in the salt compartment in the base of the dishwasher. Open the door and pull the lower basket out. You should then be able to see a cap near the front-left corner of the base of the dishwasher. Unscrew this cap (anti-clockwise) and fill the compartment with salt all the way to the top - or with as much salt as you have in the packet - then screw the cap back on firmly, but do not over-tighten it. The salt compartment will (or should!) be full of water and some will spill out as you fill it with salt. This is totally normal and not indicative of any problem.
Do not use any type of salt which is not sold specifically for dishwashers. The dishwasher can be used without salt but it is not advised and may result in a white film being left on your cutlery, glassware and/or dishes.
It may also be possible to provide a user manual in PDF format which you can download, but I would need to know the model number. If you don't know the model number Most Neff/Bosch dishwashers have the model number laser-etched into the stainless-steel at the top of the inner-door or the rim of the washing compartment. Please click on the link below for a guide to locating the model number of your dishwasher. (Neff is a Bosch owned brand)
http://www.bosch-home.co.uk/type-plate-details.html?aftersales=dishwashing&aftersales=dishwashers~16468
Hope this helps. Please let me know if you would like the manual or need further assistance.
Regards,
BElectric
7helpful
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
1helpful
I have just purchased a new Miele dishwasher. I filled the salt reserve as required but whenever the cleaning cycle finishes it reads Add salt! The salt reserve is already full! Please could you...
Hi Carol
You MUST add water into the softener reserve chamber, normally water first then salt.
Dont worry its a common mistake.
Many thanks
I have a Bosch SHU66C02UC/14 dishwasher that leaves a white deposit on the dishes especially plastic drinking glasses. Suggestions are that it is not dispensing enough rinse agent. How can I adjust that...
This could simply be a detergent problem, but is most likely due to a low salt level in the water softener. The salt is used by the water-softener to prevent hard-water deposits which result in white stains on crockery and glasses. There are several things which can cause this:
1. There is no salt in the salt container.
2. The lid on the salt container isn't screwed on properly. (Don't overtighten though!)
3. Water softener is set too low
If you've checked and topped up the salt level and the lid is screwed on fully, then your water softener may be set too low. You should consult your user manual / installation instructions to change the setting.
The white deposits can also be caused by the rinse-agent being set too low. On your washer, the adjustment will be on a dial under the flap where you refill the rinse agent. I think it's numbered 1-5, so if it's set on 1, try number 3, if it's on 3, try 4 or 5. You may have to adjust a couple of times until you get it right.
If this doesn't solve the problem, try changing your detergent. Check the packaging and if your using phosphate-free detergent, try one containing phosphates. Phosphate-free is more eco-friendly though!
How much salt should you use in a refill of a dishwasher in a hard water area
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Water hardness is measured in either European °E (clarks) or in the German °dH ( Deutsche Härte) you will find this on all Bosch Dishwashers here is the comparisons for the two.
If your water is Very Extremley hard then you will need to program your Bosch dishwasher using the Code
H:06 to give you maximum protection here is a comparison table for the codes and the Clark and Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
