If your Nescafe Dolce Gusto Mini Me is leaking milk from the bottom, there may be a few possible causes:
- Check the milk capsule: Make sure that the milk capsule is inserted properly and is not damaged. If the capsule is damaged, it may cause leakage.
- Check the milk frother: If the milk frother is clogged or not working properly, it may cause the milk to leak from the bottom. Try cleaning the frother and see if the problem persists.
- Check the machine: Check the machine for any cracks or damages that may cause the milk to leak. Also, make sure that the water tank and drip tray are properly in place.
- Contact customer support: If none of the above solutions work, contact the Nescafe Dolce Gusto customer support for assistance.
In any case, make sure to clean up any spilled milk thoroughly to avoid any safety hazards.
