Fuel pump relay or no sure if this carries a coolant sensor if so [parts people can look it up see if it comes with coolant sensor\ in my working on autos and trucks it was a bad coolant sensor Mike L.
Can\'t really help you with the no start problem without more information, but would advise you to stop using starting fluid right away. Starting fluid is hard on Diesel engines but they are made for much higher compression so will usually survive intermittent use of starting fluid. Gas engines just plain can\'t handle the much higher than normal compression that starting fluid produces which will destroy valves, piston rings, connecting rods, starters, ring gears on the transmission and head gaskets in short order. If you don\'t want to have to completely rebuild your gas engine don\'t use starting fluid on it ever!
SOURCE: 2001 Ford focus se automatic
First check battery cables for corrosion and bad connections check the battery voltage you should have 12-13 volts at the battery then see what you have at the starter where the battery cable is connected.You should have at least 12 volts there too.If you don't have 12 volts at the battery replace battery.
SOURCE: My daugthers 2003 Olds Alero
This sounds like there is a dead spot in your starter. The easiest way to resolve this issue is to replace your starter. Many times, if you take a lot of short-distance trips over the life of your car, the wiring inside the starter itself will wear (short trips means starting it more often, causing a lot of wear over time). Then the inner wiring of the starter wears too much, it forms a "dead spot" -- when the starter is stopped at a very specific spot i will not form the magnetic force needed to torn the starter motor. This is a common issue which can be dealt with for a time if you have to save the money to replace the starter. Tapping the starter, or arcing it with a screwdriver makes the inner workings of the starter jump a little, allowing it to move out of the dead spot and kick over as normal, but it is only a temporary fix. Unless you refurbish electronics for a living, it is very unlikely that you will be able to repair the starter on your own, and such a repair takes some time, so you are better off to replace it than try to repair the starter itself.
As long as the starter does not happen to stop in the dead spot, it will work as normal ... but in time the dead spot will spread, causing the issue to worsen. You can keep forcing it to turn with the two tricks you used until you have had the opportunity to earn the money to replace the starter (or until you have a day off to get the repairs done) .. but over time this can cause more damage to other parts of the car, so I recommend replacing the starter as soon as you can.
Most Fords have a fuel reset button. When you ran out of gas you tripped the circuit. Most of the time the button will be on the passenger side by the kick panel. The exact location should be in your owners manual or your local library or auto parts store will have a copy of one for your specific vehicle.
SOURCE: My car turns over but won't start, when started
The year make and model would be handy to know.
You would need to check the fuel system and find out why you don't have fuel to the injectors or carb.
SOURCE: we have a 2001 ford escape, tried to start this morning, plenty of cranking power just won't fire?
sounds like the fuel pump thats how they go try bangging on the gas tank it may have a rust buld up
