My 13VT-K100 Sharp TV/VCR combo is stuck on AIR, so I can't get all the channels available to me via my cable at school! I'm thinking I need to access the on-screen menu and change it to "CABLE" and then reprogram the channels... Only problem is I don't have the original remote and the universal remote that I'm using only allows me to get as far as calling up the on-screen menu with the MENU button -- when I try to navigate the menu with the arrow keys on the universal remote, it just won't respond! So my universal remote is useless in this case... Any way to access/navigate the menu using just the television's buttons to get this done??? ( Or anyone know where I could get another original remote for this thing? )
SOURCE: tv vcr combo cannot program tv
Try pushing the volume buttons in the middle so that you are mashing both the up and down button, your menu should appear. then you can use the channel buttons for moving up and down.
SOURCE: no remote or tv manual
Browse through the Radio shack brand here and see if you find what you need.
SOURCE: no remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
SOURCE: do I need a digital converter box for sharp 13VT N100
Yes you will need on because you are receiving a analog signal and will not decode the digital signal without one.Hoe this answers you question.
SOURCE: Any way to access on-screen menu on Sharp 13F-M50 without remote
try ebay with the model number; I had the same thing with a sharp set I own---only way to access the menu and do things is with an original remote--if this was helpful please vote for me.
What do you mean??
I have the same problem I have lost my original remote and i need to auto program my tv so it will have all of the cable channels is there a way that I can auto program this tv without the original remote because universal remotes can not use the menu the farthest it goes is to the menu and it will not go up or down so I can program it please help me
can,t get tv out of cable mode because i do not have the remote that came with the tv so, how do i fix this problem also can i access the menu without a remote
same problem
same here.
can't add or delete channels since the original remote dont work. i have to use different vcr to access the channels.
i HAVE THE SAME PROBLEM...ANY THOUGHTS??? 727-776-8793 [email protected]
