Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD52525 had a blue screen when turned off
Previously the TV had blue screen when I turned off the TV. Now it won't come on at all. The green light comes on but ther is no picture. Thanks in advance jmicic
  • Anonymous Aug 12, 2007
    The blue screen only occured when I turned the TV off. When it was on the picture was fine.
    Genius:
  • 1,153 Answers
Perfect Blue screen usually means video problems. Leave unplugged and try again to make sure.
Posted on Aug 12, 2007
6ya staff
SOURCE:
There are light blue dots on the center of my Sony television and there seems to be more and more dots each day with a light blue sploch on the bottom of the screen. The light signalling me to change the...
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team at 1-239-768-7547 and ask for the recall issue Sony had repaired free of cost for such issues previously. Hence, contact the customer relations.
Sep 14, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubiushi wd52525 nstatys ligts keeps blinking green. Lost power when the TV was on and now i have a status light that just keeps blinking green.
Unplug for a minute, when pluged back in light should blink for a few then go out, should be able to power on after that!
Dec 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
I need the schematic for mitsubishi television wd52525
go to www.blinking-green-light-of-death.com
it shows available.
Nov 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA 52" TV
Here is your other post.
Feb 25, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
354 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
