Hi, i have a sony vpl cs5 and i want to get rid of the yellow and purple spots that are on the screen
SOURCE: it just wont turn on
Pls open the Lamp unit and check it if it is giving the power indication on the panel.
Viren
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
SOURCE: Lamp change
You have to go to the settings on the projector and reset the lamp timer.. Go to your on screen menu and go to settings.. Good Luck
SOURCE: Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
SOURCE: my vpl cs5 projector is 5 years old. It has no
The problem I can confirm is either one of two faults in the main power supply section.It is either one of the double diodes in the TIP type casing which has gone short, or the other most common is the main oscillator IC in the primary of the power supply.Please check the double diode first as the main IC is about twenty pounds very expensive.Please also note change the three capacitors in the primary power supply section whilst you are at it.kind regards John Williams www.jvsvisual.com engineer to the stars.
