Cobra 29 LTD CB Radio Logo
Anonymous Posted on May 10, 2013
Classic diagram turner+3 mic wiring diagram to a cobra 29ltd classic
DROPNDEAL
Level 3:
Top Expert:
  • Cobra Master 2,931 Answers
  • Posted on Feb 04, 2018
DROPNDEAL
Cobra Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932543
Points
21770
5 Related Answers
Anonymous
  • 773 Answers
  • Posted on Apr 25, 2009
SOURCE: i want talkback on my cobra 29ltd classic radio
Open the case on your radio. Solder a 100 ohm resistor between the pa jack and ext speaker jack. You can add a switch if you like to turn it on and off. The lower the resistance, the louder the talkback.
Anonymous
  • 10 Answers
  • Posted on Jan 13, 2011
SOURCE: HOW DO I SET THE
http://www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm
29LTD ST Owners Manual
Anonymous
  • 2468 Answers
  • Posted on Jan 16, 2011
SOURCE: Cobra 29LTD Classic blows fuse
if it blows the power fuse even with the power switch on the radio off andif it has been inadvertently connected reverse polarity as in the red and black wires were hooked up in reverse,there is a polarity protection diode on the board where the power wires enter the unit,and it shorts out to protect the unit it looks like a standard diode with a white band on one end and will show a short in both directions if defective and high resistance in one direction and low resistance in the other direction if good,if it blows the fuse when switched on,then it can be a leaky or shorted audio I.C. mounted vertically on the side of the radio case,usually has 8 or 10 pins in a row soldered to the circuit board or possibly the R.F. preamp or final output transistor on the inside rear panel of the radio next to the coax antenna connector
wood butcher
  • 32 Answers
  • Posted on Feb 20, 2011
SOURCE: wiring a turner roadking76 to
1-shield/red 2-white 3-blue 4-black yellow N/C
anymhz
AnyMHz.com
  • 500 Answers
  • Posted on May 16, 2011
SOURCE: cobra 29ltd wiring diagram for mic
1ground
2audio
3tx
4rx
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.(same as the 4 pin exports)..
Use a ohm meter to find the correct wires on your mic switch.
then you know how to wire any mic to any transceiver.
This will work for the turner 2+2
2answers
3helpful
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Wiring a turner roadking76 to a cobra 29ltd
Cobra 29ltd CLassic, TX power and audio is ok, volume from spkr is good, squelch works but no cb recieve.
Try a new Mic. Make sure its a working mic. If you have a bad mic, the receive will not work.
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
2answers
Help with cb radio
Hello there
here is a link for the scematic ok?
best regards michael
  1. Cobra 29LTD ST, 29WX ST 29LTD ST Owners Manual. 29WX ST Owners Manual. DIAGRAMS. 29LTD ST Schematic Diagram ... WX Schematic Diagram. 29LTD, 29LTD ST, 29WX ST Factory Service Manual ...www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm - Cached
1helpful
I am trying to find a wiring diagram for a telex turner 56 road king to use on my cobra29ltd can any body give me one
Cobra Models: 21, 25, 29, 89GTL, 1000GTL..
Your Mic colors to the Numbers on the Mic Plug are..
Turner:
1-Shield & Red
2-White
3-Blue
4-Black
I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
5helpful
The wires came of the plug of my Cobra Road King 58 mic. I need the wire diagram to put them back on.
if you have a cobra radio with four pin input and a turner road king 56 it goes like this. pin one shield and red wire,pin 2 white,pin 3 blue,pin 4 black and tape up the yellow wire it isn't used. the numbers should be on the plug if not look inside your jack on your radio. hope this helped
5helpful
Astatic 636l microphone Cobra 29ltd classic
pin 1= sh & bl
pin 2= wh
pin 3= red
pin 4= blk
yellow = not used or put on pin 4
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
