Hello, Typically when that happens a part called the diode is bad. IT IS EXTREMLY ADVISED BECAUSE OF THE HIGH VOLTAGE AND REAL POTENTIAL FOR RADITATION THAT ONLY A PROPERLY TRAINED APPLIANCE TECHNICIAN REPAIR THAT
If will does not heat or boil water, then your microwave is defective even if it appears to turn on.
If you do not hear the 'usual' humming noise that the microwave normally makes when heating, then the Magnetron is most probably defective: if the unit is out of warranty, it will not be worth replacing as it is quite expensive.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will help you to figure out what is wrong with your
Microwave Oven....
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
