Sony XL5300 Replacement Lamp for XBR2 SXRD Rear Projection Television Logo
Posted on Mar 16, 2009
TV Wont turn on - Red Blinking Light under Lamp
Sony SXRD 55 Inch
KDS55A2000
TV wont turn on and even when it is off the red light blinks
  • Anonymous Mar 14, 2014
    blinking red light when trying to turn on the tv
  • Anonymous Mar 23, 2014
    Turn on tv no picture red light flashes
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2673
Points
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
I need help troubleshooting
Hello, How many times does the red light blink and repeat? Are you sure all the covers and doors are correctly in place?...tks
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
2helpful
I have a sony 55"
3 times red standby light flashing indicates that lamp cover (first thing that you removed from tv to replace lamp) is not fixed properly on tv, make sure lamp cover is attached correctly with tv to solve this issue.
3 times blinking is not problem of fan or anything else, it is related to lamp cover that engages safety micro switch inside to turn On tv.
Thanks.
No power to tv. When i press the power button i only get a blinking green light then it stops and the blinking red light for lamp flashes and keeps flashing
You need to replace your lamp. Also check power supply and ballast board. Most of the time if you replace the lamp it will come back up. After replacing the lamp you will need original remote to reset lamp hours.
1helpful
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
No video no sound red standby light continous blinking once per second
Red Lamp light might be blinking in your TV, that means TV needs new lamp as existing lamp inside TV is broken or dear.
Please replace lamp in your Sony KDS-55A2000 TV and lamp replacement procedure is written in user manual.
Let me know if you need user manual copy.
Thanks.
1helpful
I have a blinking red light with no picture
Blinking red light shows TV got some problem internally and need to be repaired.
Now important thing is how many times that red light blinking? There would be pause of 3 seconds in blinks so count pause to pause and let me know to find out possible cause of problem.
Is it Sony KDS-55A2000 model TV or any other model?
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
