SOURCE: CONNECTING TO THE INTERNET ON MY COMPUTER THROUGH MY I-MATE PDA2K
atta, you are asking a different question, not the same problem. YOU want to use bluetooth to transfer files. The other guy wants to use his phone as a dun.
so, for the other guy.
On this particular phone, only bluetooth dial up networking will work. It will not work as a cable connection. You have to pair the phone with the computer, then set up a connection under dial up networking as a bluetooth modem. The phone number will depend on the network. As I don't know your operating system, I don't know which dun to set up or how to set up your specific bluetooth pairing.
good luck.
SOURCE: i need to download software and Desktop for
hi thanks for using fixya!
Try to go to www.microsoft.com or www.imate.com
Regards!
SOURCE: i-mate PDA2k
To be sure if its not the battery thats bad, connect it to the charger and charge for a while. Monitor the light indicator at the top right of the phone.It should start from red to green after its fully charged. then try to restart it by turning on the power button also at the top right of the phone.
If after these procedures the phone does not start up or it shows some temporal 3 seconds flash of power, you may need to get another battery. If a new battery does not start your phone,then its a power fault.It needs to be rapaired.
The i-mate pda2k is not a 3g phone! its only a 2g phone. But you can connect to the internet by using your wireless lan and GPRS.To connect to your computer, go to your phone settings menu then select "connect phone as modem",this will give you the option of connecting through GPRS or otherwise. You must have your settings set up properly to use this feature.
