Thomson DPL909VD System Logo
Anonymous Posted on May 08, 2013
Thomson service center in Pakistan
The system is not showing display on display screen but the led for power supply is on and the service center in Karachi is no more exist
1 Related Answer
Anonymous
  • 14553 Answers
  • Posted on Aug 27, 2012
SOURCE: thomson 32wb842s stays in standby mode can i plz have service manual as there is no workshop in karachi pakistan who can solve problem in this tv plz help. b4 this broblem the picture was cut from top
there will be no service manual as thompson does not provide them.-Its a throwaway set.
LG W1934S turn on, power led shows blue light, but no display
so working on super old 2007 PC monitors. and no PC connected."? it is NOT ANY LED BACK LAMP monitor here.
came new with XP PC's.
the monitos all good to sleep mode if no PC vidoeo connected.
in the usa, even by law, (energy star)
how ever lacking a PC, the screen will show "no signal entering sleep mode"
VGA monitor.
LED = blue on, amber sleep, LED out, oFF.
NO 1080P mode allowed, (so common now) <<<< big clue here.
set the PC to 1024 x 768 (to test ) 60Hz.
using a flash light (torch) tool,.
turn on Monitor, see blue LED
point flash light to screen, see data, now, on sceen in the beam
now you now CCFL backlamps are dead. as most are this old.
Display Modes (Resolution)
640 x 350
720 x 400
640 x 480
800 x 600
832 x 624
1024 x 768
1152 x 870
1152 x 900
1280 x 1024
1440 x 900
proof BELOW. A FREE MANUAL TOO.
page 47, see 4, CCFL jacks and HV supplies here 600VDC
free service manual with full schematics and BOM
https://elektrotanya.com/lg_w1934s_flatron.pdf/download.html
in my shop I have VGA signal generator to maKE WORK EASY.
3answers
Thomson DPL580HT
The display or wireing may be broken if everything else is working fine.
here is a service manual for your product
http://www.user-manuals.com/advanced_search_result.php?keywords=Thomson+DPL580HT+service+manual&amp;forward=plist&amp;osCsid=7764b2ed878bdcc97c1d3006ca77b4bc
with the guide of the service manual you can replace the screen if it is the only problem in the device.
Toshiba e-Studio356SE firmware update failed?
Can anyone give me Toshiba e studio 355 firmware file? or a download link?
The screen keeps going black but u can here the volume
It's possible there's something wrong with the power supplied to the display or the LEDs in the TV. Usually these things can't be fixed without taking it to a brand service center.
The monitor screen goes dark about 10 minutes
Please verify the power option setting present in 'control pannel' option once. If you have selected to turn off the power supply after 10mins, (once the system is in idle state) then the SMPS will stop supplying power.
thanks.
Hi, All the lights on display are off. The system plays, but no info is displayed
some of possibilities are:
a) a burnt out LED (light emmiting diode) inside the display (could be tricky or difficult to change it) or a faulty LED power supply line
b) if the light source is an electroluminescent panel, possibly the panel itself or the power supply is faulty (electroluminescent panels use an elevated voltage power supply which is in the shape of a small box somewhere inside the housing, with two wires going to the panel - it is also possible that the power supply is not in the form of a box but is in fact an integral part of the circuitry).
c) a loose wire contact - check the connectors for any broken wires, oxidation on contacts or loose solder points for connectors on the circuit board
Anyway, these are just possibilities so the trouble may as well be somewhere else in the system.
regards
3rq8 (Triarcuate)
1helpful
2answers
Home theater System
check for any fuse blown or power supply operation.
give mfg and model to rearch for a diagram on web.
Top Thomson Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Mikey
Mikey
Bob Kirkwood
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
