Question about Fisher and Paykel GWL11 Top Load Washer
Aquasmart fault 245 - Fisher and Paykel GWL11 Top Load Washer
  • Fisher and P... Expert
  • 555 Answers
Aquasmart Error Codes
Posted on Dec 13, 2013
6ya staff
SOURCE:
Fisher paykel aquasmart error 245
Have you removed the inner bowl and check under pump cover ,if so have youput the cover on around th correct way.Is the flapper inside housing of pump obstructed.
Feb 12, 2014 | Fisher and Paykel Aquasmart wl80t65c
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Secondary Source: Pump System.
Action: Follow procedures as for Fault Code 249.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Fisher & Paykel Aquasmart WL80T65C 5 years old with fault 245, then 49.
Error code 245 is pump stall.
If the 1.6amp glass fuse has blown, the five mosfets on right side have shorted out there legs & blown the fuse.
Also check the pump drive parts for shorted legs.
There are three resistor that burn out near the fuse.
I will up loaded some pictures later.
Feb 08, 2013 | Fisher and Paykel Aquasmart wl80t65c
What is the service code #245
AquaSmart Error codes
Your pump has items jammed in the impeller.
Jan 05, 2013 | Fisher and Paykel Washing Machines
What is the service code # 245
Jan 05, 2013 | Fisher and Paykel GWL11 Top Load Washer
Error codes 49 and 245
Fault code 49 is water valves - usually, the stop working when the rubber diaphagm inside gets hard, so a resistance only test is not conclusive (only tells us the solenoid is OK).
- Do a cold fill and a hot fill (briefly) to check for strong water flow on both.
- Regarding code 245, does water pump out strongly?
- One more thought, because these codes are both related to the water level in the machine, remove the level sensor hose at the controller end and blow into it to clear any blockage.
Jan 30, 2018 | Fisher and Paykel Aquasmart wl80t65c
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Sep 03, 2008 | Washing Machines
Open Questions:
See all Fisher and Paykel GWL11 Top Load Washer Questions
Fisher and Paykel GWL11 Top Load Washer Logo
498 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
