Please go to mobile setting and turn on wi-fi on your mobile phone.
Now wi-fi network is on.
below your are showing wi-fi connection names.
now click on wi-fi connection and connect.
now asking for password.
enter correct password and click ok .
Hello Mr raju, I kindly ask you to post the problem clearly or please select any one question from the following 1.Is your phone asking a password while switching on? 2.Is your phone asking for a puk code? 3.Is your phone asking for a password which you have already set but forgot? Please select any one from the above questions
actually when you put password on memory card its store on phone memory so formating the phone also wipe your password,the only solution for that is try to restore your phone if you did backup your cell phone before formating,
Try sending an MP3 to the Parrot kit. I couldn't even get the Parrot BT in my car to ask for the BT password numbers but found out to try sending an MP3, which will fail by the way, and it asked for the password finally.
There was an error in my case, but then the phone asked to connect to the Parrot again and the pairing worked.
There is an issue with newer Nokia phones, something I will be thinking about next phone upgrade.
If you are referring to connecting your pone to your blue tooth device(dongle pluged into your computer?), you activate the blue tooth on your phone, plug the device into youre computer and right click on the blue tooth icon in the bottom right corner which will appear after a few seconds.
Click on ad device, your device will then search for other blue tooth devices. Your phone must then appear. double click on your phone, then you will be asked to enter a password. Enter anything and then next. Your phone should now ask for a password then enter it.
hello, if you know the password of your cell then go to stings and hit up the restore all data it will ask you for password enter pass cell will be restart ofther restart your cell totally format and reset.
Hello alney. yes it is possible to connect your phone to a pc via usb. however you do not need an installation cd for this process. if your computer does ask for a cd just cancel the installation and go to "my computer" look under removeable devices and you will see a "ms device" and that is your phone which you can transfare files into. also notice that your phone will only connect in idle mode when its open and unused at the moment. after connecting the usb to the side of the phone your phone will then ask if you want to use it as a storage device if you click yes it will then connect to your computer. I hope i helped. GOD BLESS you to!
