1. Uing the appropriate sized drift punch, tap out the steel axle rod which passes through the beater drum.
2. Each end cap houses a 608ZZ ball brg.
3. Check each brg for freedom of smooth rotation. Replace both if either is seized.
4. Replace with either 608ZZ (dbl shielded) or 608 2RS (dbl sealed) brgs.
5. Inspect and be prepared to replace the drive belt since it may have been damaged in the seizure event.
