I have an EYEFI LX4700 tv set. There is no power whatsoever when plugged into the elctrical outlet. I suspect I need a power supply for the set. Do you guys have on in stock?
I have a stock / part # of: 782- l47k47-2008..
Thanks for your help
Hi.About your EYEFI power supply. Did you check the blue electrolytic capacitors on the P.S. board? I have a power supply board here for the same tv. There are 6 of the 35 volt /2200uf capacitors. They all look like they have been a little overheated on the top of them.If you look at the top of them real close and compare it to a good one somewhere else on the board you might see a difference in thier appearance. The top of the canister should be extremely flat and the blue wrap around it should not be stretched.On mine it is slightly noticable that these 6 capacitors ar beveled and the blue wrap is stretched some and I think if I replace them it will work.I have done this kind of work for many years then got out of it.I'm getting back into it because I like doing flatscreens. It would be alot cheaper for you this way. I haven't located a parts place yet to order them. They have a white silicone around them and maybe thats because they get really hot. I don't know a flatscreen that likes too much heat or too much moisture for that matter. There is a place that has these power supplies for sale but he is out of themright now and personally if it's more then 50 bucks it's a rip His are 49.99 w/free ship.Don't let anyone tell you that because EYEFI went out of business that you can't find these There is a guy on ebay selling them for 139 bucks/frigin rip off. I told him good luck with that..lol. Anyway hope this helped. If you find one cheaper and in stock please let me know. Thanks and good luck. Lisagee:)
hey didit work just fine then not turn on at all?
I need a digital board Part # 782-L37T73-010A.
