Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Redwine2
Do I need to off set the Y pipes too by moving one higher or just clean out the vent stack?
i recently tiled my kids bathroom, I replaced the toilet after tiling, however every time I flush the toilet in the master bath room their toilet makes a noise
