AS in title , iv took everything out and left it off for a while and put it all back together again but still getting the error , this is stopping it printing off faxes as well.
SOURCE: Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
SOURCE: Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
SOURCE: canon pixma mx 860, I
its a message from the modem in the fax
make sure the line is ok and he cable connected to the right place
if not helping than its better to send to service
SOURCE: I have a canon pima mx340 printer/fax machine. How
Printing a Memory List or Specified Document in Memory 2. Press the FAX button, then press the Menu button. The Fax settings screen is displayed. 3. Use the button to select Memory reference, then press the OK button. 4. Print a specified document or memory list. Use the button to select Print memory list, then press the OK button. · To print a specified document: 1. Use the button to select Print specified doc., then press the OK button. 2. Use the Numeric buttons, or the button to select the transaction number (TX/RX no.) of the document you want to print, then press the OK button. 3. Use the button to select Yes, then press the OK button. If you select Yes, only the first page of the document will be printed. If you select No, all the pages of the document stored in memory will be printed.
To print other documents, repeat the procedure from steps 2 to 3.
