It seems like you've tried various connections and settings to get your JBL135 subwoofer working with your Kenwood receiver, but you're still facing issues. Let's break down the situation and provide some recommendations:
Subwoofer Connection:
Using the LFE/Subwoofer Out: This is the preferred method for connecting a subwoofer. Ensure that the cable is firmly connected to both the subwoofer's LFE input and the receiver's Subwoofer Out port. Make sure you have enabled the subwoofer output in the receiver's settings menu.
Subwoofer Settings:
Gain: Adjust the gain knob on the subwoofer to achieve the desired bass level. Experiment with different settings to find the right balance.
Crossover: Set the crossover frequency on the subwoofer to blend with your tower speakers. Start with a conservative setting, such as 80Hz, and adjust as needed.
Receiver Settings:
Speaker Configuration: Set your tower speakers to "Small" in the receiver's settings menu to redirect bass frequencies to the subwoofer. This ensures that the tower speakers are not trying to reproduce deep bass.
Bass Management: Enable the appropriate bass management settings in the receiver's menu, which typically includes crossover frequency and speaker size adjustments.
Check Subwoofer Cable and Port:
Ensure that the subwoofer cable is in good condition and securely connected to both the subwoofer and receiver.
Try using a different cable or testing the subwoofer with another receiver if possible to rule out cable or port issues.
Factory Reset:
If you've exhausted all troubleshooting steps, you may consider performing a factory reset on your Kenwood receiver. This will reset all settings to their default values, potentially resolving any configuration issues.
If none of the above suggestions work, it's advisable to consult the user manual for your specific Kenwood receiver model or contact Kenwood customer support for further assistance. They can provide more detailed guidance based on your equipment and setup.
Electronics companies use other major companies as a vehicle for their products. The VW Group in this case is one of the major corporations that Kenwood uses.
Yes. It needs to know you have a subwoofer or it won't send low frequencies out to one. Then you have to calibrate its level to match the rest of your speakers. Hit the SETUP section in the manual (available at retrevo.com).
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
if u have a pair of rca connectors, connect audio out of your dvd dvd receiver to audio in of your tv. they are usually red and white,, for right and left speaker.
"Sub-woofer output not working" problem, and notify you when a new solution is offered. Press the setup key on the front of the receiver Select the subw setting Move the multicontrol knob until the sub woofer is on Turn off the receiver and turn back on- the subwoofer should be on The operator manual can be downloaded on the web site--- free http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
HI...
Check the kenwood consumer site 1st.
Can you get me a pic of what the connect looks like on the back of the rec'r??
