I can't seem to set the time for an Acu-rite alarm clock with temperature readout.This is a clock that sets itself but it's an hour behind, cna't find a model number
SOURCE: Lost the manual for setting the Acu-Rite clock #
You can get the manual on the link below.
http://www.acuriteweatherstation.com/modelmanuals/INST_13131A3.pdf
SOURCE: setting clock
I think I solved the problem, take out the batteries and reinstall and then reset, seems to be doing ok now.
SOURCE: How to set the time on Acu-Rite model 13100 clock?
Go to:http://www.atomixtime.com/pgs/pdfs/13003%20THOR%20INSTRUCS.pdf
and print it out.
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
