Question about Wega Mininova EPU Espresso Machine
MY BUNN COFFEE MAKER LEAKES WATER
MY BUNN COFFEE MAKER MODEL # GR10-B CODE 121502
REPAIR CODE # 3305
WHEN MAKING COFFEE THE COFFEE MAKER LEAKS WATER...
WILL BUNN SEND ME A REPAIR KIT FOR THIS MODEL?
WILL I BE CHARGED FOR THE KIT?
OR SHOULD I JUST PURCHASE A NEW COFFEE MAKER?
NOTE THIS IS THE SECOND BUNN COFFEE MAKER THAT I HAVE OWNED AND BOTH HAVE LEAKED.
MAKES YOU WONDER IF IT IS WORTH THE TROUBLE BUYING ANOTHER BUNN OR EVEN TRYING TO REPAIR THIS ONE.
THANKS FOR YOUR TIME,,
HARVEY KISER
11325 W. HWY 60
OLIVE HILL, KENTUCKY 41164
  • Anonymous Mar 16, 2014
    best way to improve flow of coffee . Used to take a minute or two, now takes 5-8 minutes cannot locate instruction booklet
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Posted on Mar 16, 2009
6ya staff
SOURCE:
Bunn GR10 Coffee Maker
Check bunn.com for free download of manual(s)
Call your vendor for service. Especially if this equipment is on loan from them,
Aloha, ukeboy57
Apr 06, 2014 | Bunn GR10 Coffee Maker
Bunn coffee maker model gr10-b water will not heat in tank
If you will call customer service with the model and date code at 800-352-2866 we will be happy to help you with this issue.
Oct 17, 2010 | Bunn B10 Coffee Maker
I have a Bunn coffee maker. I have had it for a few years but not sure how long. Recently it started to leak water from the bottom and causes a huge mess. The model number on the bottom is GR10-W. Hope...
If you will call Customer Service with the date code and model, we do have a seal kit we can send out or offer you an out-of-warranty exchange. The number to call is 800-352-2866.
Sep 04, 2010 | Bunn NHB Coffee Maker
Hot water leaks out the bottom when filling resevior with water of my Bunn coffeemaker GR10-B
If you will call 800-352-2866 with the model and date code and we will be able to help you resolve your issue.
Jul 01, 2010 | Bunn GR10 Coffee Maker
Switch wiring
If you will get the model and date code from the bottom of the machine and contact customer service, we can further assist you.
Jan 22, 2010 | Bunn GR10 Coffee Maker
Bunn perks coffee very slow?
This is generally an indication of a lime build-up in the water tubing. If you take off the sprayhead and insert the metal deliming tool into the water tubing all the way leaving out about 1-2 inches and twist it about 5-6 times, this should remove the lime deposits from the water tubing. Then flush out the machine with 2-3 decanters of water. If this doesn't fix the problem, then call customer service with the model and date code for further assistance.
Aug 01, 2009 | Bunn GR10 Coffee Maker
Basic Bunn Coffee makers will not light up
look on the left hand side down by the bottom there is a switch try that.
Feb 12, 2009 | Bunn GR10 Coffee Maker
Bunn GR10 has a hole in the panal where the water runs into the
The only place I know of that you might be able to find a replacement tray for this style of brewer is from your local Bunn repair shop IF they have a used unit laying around that died from something else. Bunn will not even send out these parts to their repair centers. Good luck!!
Feb 04, 2009 | Bunn GR10 Coffee Maker
Owner of a GR10 Coffeemaker
take the spray head off, should have 5 holes clean it out and run the cleaning spring through where the spray head screws to.
Sep 21, 2008 | Bunn GR10 Coffee Maker
Wega Mininova EPU Espresso Machine Logo
833 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
80stech
Guy Tzur
Guy Tzur
Level 1 Expert
Vitally Alcher
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
