I have a HP Laserjet P3005 hooked to a Print server DP301U and i have problems printing from the workstations. the print job from the work station is sent to the print server but it seems that the print server doesnt send the print job to the printer, and the printer status in the print server coontlol panel says "printing" y made a test by instaling an old lexmark laser printer and had no problems with it. the workstations are running under win xp , thx
I got my dp-301u to work fine with my hp1020 on 2 different
workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3.
once created go into the properties of the 2nd printer and change the
port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
I have the same problem with P3005 and D Link!!!
I have the same problem with s canon mf4100, any suggestions?
Hi:
I have the same problem with a canon Mf4100 any suggestions
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
i try that and get the same results...update....after several tests i manage to print from the work station, but not in a normal way.i did the following procedure: 1.- first i open a document(word excel, etc) send a print...does not print....2.- reset the print server without closing the office application...3.- send the print again and... voila! i can print...the bad issue is that if i close the application and open it again i have to do the same procedure described above.. funny isn't it.
I have configured the USB printer HP 1020 Plus in DP-301U print server.
Initially while configuring in tcp/ip port, it was printing, but when I switch off the printer and switch ON. The job is not printing at all & its not in the queue.
But when I check in printer folder, the job assigned and disappear.
Please assist me.
Still facing the same old problem.
Need anyone assist at the earliest.
