32'' TV connected to TW cable, works fine for 10-30 minutes, then blue screen + ''no signal'' message. Cycling through functions on remote to return to ''Component 1'' restores programming, for a short time, then ''no signal'',again. Loss of component 1 is signalled in upper left of screen by showing ''Component 2'' - if I am quick enough, pressing Proscan remote ''volume'' up or down prevents signal loss, for a very short time.
Sometimes, turning TV off for a few minutes, then back on, gives another 10 minutes or so of programming, before ''no signal'' is displayed, again.
TV is not wall-mounted, no other devices present. Probably not overheating, as I set up a box fan to cool it - no change. Connection is a 5-strand cable from TW's Motorola cable box.
Any help appreciated.
SOURCE: hdmi does not work
go into TV menu and turn the HDMI on. guessing it should be in settings? or Video input.
SOURCE: tv jumps randomley between different inputs HDMI, component, ect
With a set that new, you should be able to return it for warranty exchange or at least warranty service. The internal logic is having a problem, the power module is not up to the task, or there are just simply a few defective parts inside. In any case, there is no reason for you to worry about this, this is the type of thing that is covered by warranty.
Try that first.
Keep us posted,
Dan
SOURCE: tv stopped working
Check input signal comming in, is there any?With another tv see if u have cable or free air signal.All that check,than ur backlight inverter board is dead.
