LCD brightness question
You can adjust the brightness or color of the LCD display as needed.
1. Set the POWER switch to CAMERA position. (In the PLAYER mode, you may only setup the LCD while the tape is playing.)
2. Open the LCD screen, and the LCD switches on.
3. Press the MENU button.
4. Turn the MENU DIAL so that VIEWER is highlighted and then press the ENTER button.
5. Turn the MENU DIAL so that LCD ADJUST is highlighted.
6. Press the ENTER button to enter the sub-menu.
7. Turn the MENU DIAL so that it highlights the menu item you want to adjust (BRIGHT SELECT, BRIGHT ADJUST, COLOR ADJUST).
8. Press the ENTER button again.
You may select NORMAL or SUPER in the BRIGHT SELECT feature and press the ENTER button to save the setting.
Use the MENU DIAL to adjust the value of BRIGHT ADJUST and COLOR ADJUST.
You can set values for BRIGHT ADJUST between 00 ~ 35 and COLOR ADJUST between 00 ~ 35.
9. Press the MENU button to finish the setting.
I tried to download update from NVIDIA and installed, but the problem still stayed the same. Can you provide me the correct driver for this card working Windows XP Pro?
I installed the driver from NVIDIA but it does solve problem. Please!!!
