Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timer flashing I just moved my mitsubishi medallion 1080 and when I plugged it back in the timer light flashes and will not stop
  • yoetz Mar 17, 2009
    same problem
James Allen wells
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 10, 2019
James Allen wells
Contributor
Level 1:
Answers
Questions
0
Helped
379
Points
My timer light is blinking till fast and power want come on
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Mar 18, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
22249
Points
158
Remove the lamp and check to see if its ok, if ok replace lamp thermal sensor
1helpful
My Mitsubishi Medallion 1080 will not come on the green light just keeps flashing and none of the buttons will work...can't find the owners manual...please help!
You can try resetting it , but most likely you have a problem on the dm board. Easiest way to reset is just unplug it for a couple of minutes.
2answers
Green light flashes on my 65 mitsubishi 1080 medallion. reset button doesn't reset it and light continuously flashes
You need to replace 4 capacitors on the "DM" board. They are 1000uf and 16v. The board is located under a metal shield on the left side of the set (looking from the rear).
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
4helpful
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
3helpful
3answers
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
[email protected]
Green light flashing
This is most commonly caused by the Formatter not booting up. The cure is to replace 4 capacitors on the Formatter board 1000 mfd @ 16vdc. The Formatter is the large stand up shielded board on the left as you look in from the back of the set. The capacitors will be domed on top if bad.
2helpful
2answers
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
8helpful
4answers
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
