Sony Alpha DSLR-A200 Digital Camera Logo
Posted on Mar 16, 2009
Can not upgrade firmware v1 tov4 in a Sony a200.
Went to Sony website to download v4 firmware for my sony a200.
Downloaded the firmware and followed there instructions but failed to install. Copied file to CF card but camera would not install it.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2129
Points
There is know update in firmware for a 200 the v4 update is for the a700
Anonymous
Level 1:
  • Posted on Apr 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2129
Points
Hi Could you please post the link to V4 Firmware. I cant seem to find any Updates on the sony website fort he a200k.
Thanks.
Just downloaded a firmware upgrade (A64E_1065.zip) to my Sony STR-DA6400ES receiver and i get error message DSP COMM.VER.ERROR! I have tried re-installing but that fails
Find a solution that solve my problem : go to US sony website and download the firmware 1.062 released on 7/12/2011. If you're in Europe you have to rename the zip file like this : A64U_1062.zip renamed to A64E_1062.zip
Then upload it to ES Utility and do the update. After half an hour, shut down your receveir (even if blinking) and restart.
Result, no more message error and everything work fine now! Firmware installed : 1.066 (!)
i think the firmware 1.065 released by sony in november was totally corrupted...
Hope that help someone ++
1helpful
I have Boot error on my NWD-B103 sony walkman
The only way to fix a boot error message on an mp3 player is to do a firmware upgrade. If the firmware is available you will find it on the manufacture's website. It's important that your computer still recognize the player when it's connected because the firmware will be have to be downloaded onto the player.
The firmware should be installed then connect your usb player. Follow the steps given on the web. By the way it will be better if you format your player as well during this installation.
I'm using the same model as you and I'm very glad to share you this.. hope you will try!
2helpful
VAIO VGN-NS240E/W PC Notebook: I upgraded from Vista 32 bit to Windows 7 32 bit (...
It is required to install the following Drivers/Utilities in the following order to fix the issue with the functions Keys.
You can click on the link to download the Drivers/Utilities.
Video Driver.
Video Driver Update
Audio Driver.
Sony Shared Library
Sony Firmware Extension Parser Driver.
Sony Firmware Extension Parser Driver Update 1
Sony Firmware Extension Parser Driver Update 2
VAIO Event Service.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
Good luck...!!
7helpful
2answers
Movie 2012 BluRay loads menu but won't play on Sony BluRay player
Sony releases new firmware for the bdp-s350 ever so often to let it play newer movies. The last one can be downloaded from here firmware. Be sure to contact Sony with any problems so they can work on it for the next firmware. They are pretty good about updates as long as we let them know of any problems we are having.
If you are continuing to have problems let me know by sending me a message in the comments and I will go from there. I will get back to you as soon as possible.
Take it easy and hope I helped.
Ive upgraded my psp v4.?? to v5.51
you need to download game that are compatiple with v5.51
2helpful
Sony didital player wount turn on
Hello and Welcome to FixYa!
I will suggest to reinstall the firmware (the operational software) on your MP3 Player.
Follow the following procedure to upgrade firmware:
  1. Connect the unit to the computer.
  2. Set up a folder on the computer hard drive. Copy all the music tracks and data from the unit into the folder.
  3. Quit all software applications running on Windows and disconnect the unit from the computer.
    * If other Digital Music Players are connected to the computer, disconnect all of them from the computer.
  4. Download this firmware file (http://walkman.update.sony.net/fw/pc/DB100/NWD-B100F_V1_3.exe)
  5. Windows Vista users: Click right click the downloaded file and select RUN AS ADMINISTRATOR.
    Windows XP/Windows 2000 users: Simply open the downloaded file by double clicking it.
  6. The program will be started.
  7. Connect the unit to the computer.
  8. If Format Data Area is selected in Download options, the unit will be formatted and all music tracks and data are deleted during the update. Make sure to backup the necessary files into the computer before proceeding to next step.
  9. Click Start.
  10. Please do not disconnect the unit from the computer during updating.
  11. When the message of completing updating is displayed, click Close.
  12. Transfer all music tracks and data to the unit that was previously backed up.
You are done. I hope this works for you.
Source: Sony Official Website
Kindly rate me if i was helpful.
Regards,
Waqar
1helpful
I upgrade my sony vaio pcg-k35 to vista but the screen does not fit the screen what graphic or video driver do i use pls.. help me with my problem.. ihave downloaded all the drivers for vista compatability...
go to the following website, scroll down and download mobility modder. http://www.driverheaven.net/modtool.php you will also need to download the lates catalyst software from ati don't worry that it isn't for your graphics card because mobility modder will change the files. finally follow all the instructions on the dh modder webpage where you downloaded it from and you can't go wrong. i used to have a sony vaio and i couldn't beleive how sony supports their customers after sale. they haven't and probably never will release a driver for these graphics cards. Shame on Sony!
2answers
Cannot play downloaded games,WHY?
because you upgrade the system of your psp to a sony official firmware that why you cannot play your games to your memory card you need mod your psp using magic memorystick, pandora battery and custom firmware so that can install custom firmware to psp.
2answers
Sony nwz b105 mp3 player
try to reset the device
yet if its not starting contact nearest service center
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
