New MOEN Faucet.
Water does not come right side.
This is 50+ year old house.
Do you think it just needs a new cartridge?
The valve (cartridge) is installed 180 degrees backwards. Remove it (cartridge assy only) and rotate it halfway and reinstall. Same for a Moen Shower valve.
Hello
i had a leak due to o ring out of place. Its a one handle pull Moen kitchen sink. when i reinstalled it i screwed up the adjustment. Now the water barely shuts off and when it does it in the wrong handle position
Good advice above first. Or call 1 800 289 6636 and explain,valve could be installed wrong.
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
If you have stops under the sink with disconnects. Try disconnecting the cold side to see if water will come out before going to the faucet. It could be a line problem and not a faucet problem.
