SOURCE: How do I get into
There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
Enter here to find assembly diagrams and parts for your model.
Contact the seller by phone if part is not listed on the website.
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
SOURCE: Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
appliance parts, help &
more
SOURCE: OVEN MAKES A LOUD NOISE WHEN IT IS TURNED ON
This indigates worn or tight fan motor bearings, if it is a built in oven , then it could have an external cooling fan in addition to the oven fan, so you will have to determine which one it is.
Usually it means having to replace the offending fan motor, as lubricating only provides a short term solution.
Hope this helps.
SOURCE: After taking my Built-in Electric Convection Oven
Use this handy GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
