I believe the Dell logo is hard-coded for the Startup, but you can change the Wallpaper form the Dell logo, to an image of your choice:
From the Setup Menu, or Others Menu, you can go into:
SCREEN SETTINGS—Select and press checkmark to activate screen settings. The screen
settings menu consists of the following options:
CAPTURE SCREEN—Select and press checkmark to capture the screen display, the following message appears on the screen.
NOTE: To capture a full image, ensure the input signal that is connected to the projector is 1280 x 800 resolution.
SCREEN—Select Dell to use the Dell logo as wallpaper. Select Captured to set the captured image as wallpaper.
RESET—Select and press to delete the captured picture and set back to the default setting.
More information available on the Manual here:
http://support.dell.com/support/edocs/acc/4310WX/en/ug/pdf/4310WX_en.pdf
