Need to know how to wire a motorguide 767 brute trolling motor
It has 1 white, 1 black, & 1 red wire. Which wires do i use to connect to a 24 volt battery system? It has a 12v & a24v switch on the side of the foot pedal.
I disconnected the wires on my 70lbs thrust motor and was wondering where I connect the white wire to. I disconnected the wires on my 70lbs thrust motor and was wondering where I connect the white wire to.
Please tell me what the equiptment is that this battery sys in intergrated with.Hi I'm Seth.
AnonymousMar 15, 2014
if i have a light switch i am replacing with a white red and black wire how do i connect it to a new switchif i have a light switch i am replacing with a white red and black wire how do i connect it to a new switch
You can't post conmments that contain an email address.
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
To get 24 volts from two batteries they are wired in series. A wire is connected from the "+" terminal of the first battery to the "-" terminal of the second battery. Your trolling motor is connect to the "-" terminal of the first battery and the "+" terminal of the second battery. You will be operating at 24 volts.
Hi I'm Seth.
