Try this. Take the handle off the tool per the cleaning instructions. Install the battery and push down on the roller lever in the upper handle. It's located close to the fan blade. (Item 27 on the tool schematic.) Keep your finger out of the way or the fan will bite you.
If the fan goes on, then the roller lever is bent and needs replacing or adjusting.
If the fan does not go on, release the lever and pull the trigger. If the fan works, then the molded circuit board needs to be replaced.
Have you disconnected it from the air source and deep cleaned the nail gun? Sometimes even a tiny bit of dirt can block the rails the rod runs in. Once cleaned add a small amount of oil to the rod runners.
Do you add a drop or 2 of pneumatic oil before connecting to the air line? This is what happened to one of my finish guns. I ended up taking my gun apart to get to the driver and nail guide; adding oil in places to get the driver to function properly again. I removed all nails(IMPORTANT) and would then push the driver back to position,put the guide back together, then fire, remove the nail guide again and expose the stuck driver.... repeat repeat repeat. Adding oil in places that looked catching. Fixed it. Works like a champ now
Remove the tool from its power source, clear out the nails, then open the nose clamp. You'll probably find that the firing pin is in the extended position, blocking the nail feed slot. Simply push it back up, using a straight screwdriver or other blunt tool. Now reclose the gun, load a strip of nails, and try it.
Your question isn't specific enough. Multiple things need to work together to fire a gas fired nail gun;
First the obvious user faults;
Low battery
Low gas
Nail guide jam
Not so obvious;
Broken/worn return springs (nail guide and firing bolt)
Faulty micro switches
Bent or impacted internal mechanism
Fan fault
Ignition or spark fault
Dirty or damaged ignition chamber (just like a car piston, cylinder and rings)
Faulty micro controller and ignition circuitry
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
NV50 nailer is very difficult to repair due to complicated feeder /feeder spring / feeder retainer pin design. You most likely need to replace the orings on the feeder piston. Problem is that you must remove the feed pin/ spring to get the piston out. If you are going to attempt to replace the orings, study how the pin is installed otherwise you will make it worse. Order new springs (2 different springs ) and install them when you are going back together. Good luck
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
As a safety precaution, nailers have incorporated a safety foot that will prevent the gun from firing unless you push down hard. Some guns also have a system where the gun will not fire at all if there are no nails in the gun. To dry fire this type of gun you must pull back the pusher or open the side door. If nails do not feed properly, check for wrong nails, bent rails or weak pusher spring. If all is good with rails and pusher, suspect that the driver/piston is not at top of cylinder and lower part of driver blade is preventing nails from advancing. Remove airline and push the driver to top and retest. If driver is slipping down the cylinder under its own weight, replace oring. Good luck
Hi, Yes you need to oil driver blade piston. You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark. Thanks, Jeff
