Does V8 still charging even if the green light is off. I connected my V8 to the computer for charging, but when adquired some charge, it turn on and off again claimed for low charge level, but it didnt start the green charge light again. Im not sure if this behavior it's right, or if the phone is still charging, even with the green light off. Any help will be apreciated
SOURCE: Battery won't charge
I have the same phone and it flashs every now and then when its charging but it charges and works fine. Is yours charging?
SOURCE: unable to charge
This is a very common problem on the 815. One thing you try is to carefully clean the charging contacts with a soft tooth brush. This will often solve the problem. Many times I have seem the contacts recess themselves in the connector. This may be caused by a poor or dirty connection, causing it to heat up and melt the plastic. The constant pressure pushes the contacts in causing the shorter center pin on the male connector not to make contact. In this case you might as well look for another phone. The connector takes very specialized tools to replace. These contacts are the "weak link" inthe e815 and cause many problems.
SOURCE: my tracfone will not come on,only the lights
You'll wanna ensure your phone is totally charged. Also, let it completely drain before putting back on the charger. This will help with the charging memory.
As for the phone. Do a master reset: to do a "Master Reset". I went to "Settings," "Other Settings,"
"Initial Setup," "Master Reset" and put in the security code. "1234" is
the security code if you have not reset yours.
It'll get the phone back to as you got out of the box, day one! Your numbers will be fine. You'll notice the ringtone and the wall paper will be the orignals.
I know this will work!
Cheers!
SOURCE: Motorola W375 won't charge online!
You'll need pc charging drivers to charge your phone with a pc and a USB cable, you can get the driver at the motorola website.
hope this helps.
