Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and please answer the questions below.
When you hit "Start" to
microwave, do the inside light, cooling fan, and turntable all
come on?
Any unusual noises? Is
it louder or quieter than usual?
We have a sound clip of
what a microwave should sound like when the cooling fan and high
voltage section are operating here
SOURCE: MY MICROWAVE DOEST HEAT
pull your magnetron connector out and clean the both pins with alcohols or a metal cleaner and then fix it again and use. magnetron will work surely.
SOURCE: How to fix an Emerson microwave 8992RD that
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
SOURCE: Microwave runs but doesn't heat.
There are no heating elements in a normal Microwave Oven: instead, an extremely dangerous High Voltage and Amperage Magnetron is used and its replacement is not considered safe for the average handyman!
Check if your unit is still under warranty and if so, take it to an approved warranty appliance repairer as directered by the manufacturer or supplier.
In any case, nowdays, the high cost of a replacement Magnetron (if you can find one) is usually more than the cost of a new equivalent Microwave oven.
Hope it helps!
SOURCE: kenmore elite microwave model 665.61689101 after
Hello &
Welcome to FixYa F3H error
means a failure in moisture sensor however, if you leave it unplugged for 15
minutes it should work, if won't then the sensor or the control board needs
replacement. Please get back to me if you have any other questions. Kevin
SOURCE: my microwave comes on lights
The most likely cause is a defective magnetron, "heats food" cost to repair will be close to a new microwave oven.
