Ruud UBHC Air Conditioner Logo
Posted on Mar 15, 2009
I HAVE A RUUD SILHOUETTE II GAS FURNACE. THE UNIT COMES ON BUT THE BURNERS DON'T. IVE HAD THIS UNIT SINCE 1995. I DONT SEE A PILOT LIGHT HELP!!!
  • ryankbrown Apr 18, 2009
    I have the same problem and the HSI is cracked for sure. I can fix this however, I am currently stuck in a blizzard and wondering if it truly is unsafe to manually light the burners? It's getting very cold...
    Please help!
Karl
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 10, 2015
Karl
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9232
Points
16
Maybe you should check amazon, here: Amazon com ruud silhouette parts. Wish you best of luck. Karl
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Mar 15, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
16715
Points
49
Your furnace probably has electronic ignition. Remove the panel that you have access to the burners, valve, electronic module. There should be a main power switch installed on the furnace. Turn it off. Set your t-stat on high. Turn on the power switch. After the unit purges (about 30 seconds) you should see an orange glow at the burner orifice. If not, Turn off the power & remove the heater and inspect it for cracks. (Or use an ohm meter) If open, replace it. Very common problem. If the igniter is of the sparking variety, you need to change the circuit board. Most of the furnaces, there is d diagnostic code chart and an LED on the board. Follow the chart.
  • Anonymous Feb 23, 2012
    what was it
Anonymous
Level 1:
New Friend:
  • Posted on Mar 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9232
Points
I have a Ruud silhouette II gas furnace. My ignitor is not lighting, so the burners are not lighting up
2answers
2answers
I have a Ruud UAKA-037JAZ central heat and air unit (Silhouette 11 gas furnace). When I turn the thermostat to heat the heat does not come on. I removed the front panel and there are 2 green lights lit up...
Need furnace model number. It sounds like you're looking for a standing pilot. Your furnace might not have one. Very likely to have a spark ignition type system or hot surface igniter.
I have a RUUD Silhouette II and every once in a while the house gets cold and I check my furnace and the Status Light blinks-pauses-blinks-pauses ect. It is only flashes once so it tells me ''One Hour Time...
You will need to reset the furnace and have it run thru a cycle (or try). After three attempts, it will blink another error code that may tell you more.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
MY ruud silhouette gas furnice unit comes on but burners don"t.can't see pilot light.the unit has electic ignitor
You either have a spark ingitor or you have a glow coil ignitor. The glow coil ignitor is located on the left hand side of the burners. It is a very fragile part.
If you have a mirror or have good eyes, look to see if
it has a crack in it.
7helpful
3answers
Ruud Silhouette II Gas Furnace, the furnace lights but will only stay on for a few seconds?? What could be the problem??
Bad or dirty flame rod.
4helpful
2answers
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Sticky manual gas valve
Sounfds like the thermostat is on the blink.?
2answers
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
2answers
Ruud RKKA Series Split Unit
the pressure switch has to pull in for the gas valve to be powered so check switch and venting
Top Ruud Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
