Microwave Ovens Logo
Posted on Mar 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fan on my microwave keeps coming on by itself
Once the fan comes on, I can't turn it off. Have to leave unplugged. Is my microwave done?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 234 Answers
  • Posted on Mar 15, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
234
Questions
0
Helped
162918
Points
513
I think the switch is stuck in on .Have you try to replace it?
Microwave fan comes on when plugged in
Could be in one of the micro switches for the door or in the board. Most commonly one of the switches though.
2answers
Emerson mw9090ss just stopped while heating something
proceed with common sense, clearly, and logically.and fix it .God bless you
Microwave overheats and keeps turning off All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
If this is your microwave oven repair problem, you will need to check the operation of the fan. Below in the component testing chart, you will see how to test the fan. Also, if possible, make sure the fan is not obstructed somehow and not turning. Also check your fan relay at your control board for voltage, if no voltage, replace control board. This fan should come on at the same time any cooking starts.
2answers
Microwave displaying SE in the display panel, it is only 5 months old.
An SE error on a Samsung microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
I have a one touch microwave & have misplaced the manual. The code F2 keeps coming up on the display. What does this mean?
F2 on a Whirlpool microwave means you have a shorted membrane keypad.
Please reply back with your full model number from the tag in or on the unit so we can help you with an estimate or free DIY tips.
1helpful
My GE spacemaker starts beeping and showing an F3 whenever I boil food underneath on my stove. Is this gonna be expensive. I can only get it to stop by unplugging.
I advise customers to always turn on the hood vent exhaust fan whenever cooking on the stove top to help keep grease, steam, and heat out of the controls of the microwave.
The heat is affecting (and may have damaged) your membrane keypad.
In some cases, this can lead to the microwave's coming on by itself, which can lead to a fire.
So if it does anything odd or comes on by itself (even once!) be sure to keep it unplugged or keep the door open when not in use.
And as with any microwave oven, never leave it running unattended.
Once you know your keypad is damaged (if it fails again) then it will have to be replaced.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Ge Microwave model JVM1650SH05 Error code F3. Microwave turns on by itself and keeps beeping
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
The easiest and quickest way to repair this yourself (it's easy) is to order a new control panel frame, which comes with a new keypad.
It's part # WB07X10959 and you can get it for $92.50 plus shipping here.
You can also find helpful exploded view diagrams at that link.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Microwave oven fan will turn itself on and off constantly when not using the regular oven. Afraid to leave microwave plugged in because it comes on and goes off so much. Kenmore model 721.62649200
It may be a shorting pad (the hood / vent fan pad) on the keypad or a part on the control board.
Absolutely - If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
If you need a new keypad, that would add about $37 to that cost.
Feel free to visit our Web site or contact me directly with your model number and symptoms.
William E. Miller
[email protected]
1helpful
1helpful
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So please leave it unplugged or leave the door open.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Microwave comes on by itself in middle of night
This absolutely is a fire hazard.
Until it is fixed, you are right to either unplug it or simply leave the door open when you;re not using it.
You have a failed membrane keypad.
If you would like to have us to do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
