My phone is cdma , but cdma fully covered place it not detect network , other phones working fine , also it worked few days ago fine , i tried to made factory reset , but i didnt find any setting on the phone , only setting is reset the internal/external memories , how do i hard reset my phone ? or how do i fix my network , help me as soon as possible
greatly tnx
SOURCE: LG Prada Cant get music on to the phone
If you have a memory card in the phone, you need to move all files to that... then you will be able to download things through bluetooth and move them also to the memory card.
SOURCE: moving files on lg prada to exernal memory
I got around this problem by, one at a time, making sure each file I sent to the phone was copied to external memory and then deleting from where it was sent to originally before sending another. Clunky and long winded, but enabled me to get lots of mp3s onto the phone.
SOURCE: LG PRADA PHONE TOUCHSCREEN NOT RESPONDING
Ok after a bit of research I understand that the Lg Prada phone uses a Capacitive touchscreen technology. Wiki this and you will find that the plastic strip attached to the underneath of the front cover of the phone (with its circuit ribbon that connects to the main circuit board of the phone) has a sticky substance holding it air tight to the underside of the front cover. This sticky substance is Indium Tin Oxide (ITO) and conducts a continuous electrical current accross to the sensor. So if you have bought a new cover from ebay etc like I have and replaced the new cover with the old scratched one, you need to get yourself some ITO sputtered onto the screen to make its capacitive touchscreen technology work again.... hope this is a more technical answer than some of the idiots that post unhelpful solutions to questions(solution 1!).
SOURCE: LG Prada Phone issues
i had this prob... how i got this prob solved (i hope) was i changed the wrong date to the correct one.. then i switched off the phone and back on.. and the prob seems to be fixed..
