Dell OptiPlex GX620 PC Desktop Logo
Anonymous Posted on May 01, 2013
Usb dongle my virginmedia dongle wont work in any of the ports,any idea's on how to fix it ,many thank's.
L Pfaff
Level 3:
Top Expert:
  • Dell Master 11,573 Answers
  • Posted on Jun 27, 2016
L Pfaff
Dell Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3584447
Points
181713
max carson
Level 3:
  • Dell Master 7,627 Answers
  • Posted on May 02, 2013
max carson
Dell Master
Level 3:
Answers
7627
Questions
Helped
1013871
Points
21773
Does it require software? Contact Virgin Media Support: http://community.virginmedia.com/
Hooked hdmi dongle to projector. Used kindle fire hdx. Picture works fine but no sound from projector speakers. No sound from kindle speakers. Need to use kindle headphone jack for sound.
follow this steps and fix it. God bless you
Check the system requirements on the Bluetooth dongle. If your system does not fit all the requirements, the device is not going to work. The requirements for the Bluetooth dongle are printed in the user manual and packaging. You may compare this to what is running on the computer by clicking "Start," "Control Panel" and "System." This displays the hardware running on the computer.
    • 2
Disconnect the Bluetooth dongle, restart the computer, then plug it back into a USB port. If you power on the computer with the dongle already instead, the system may not detect the equipment. Restarting the computer and performing this action helps correct the problem.
    • 3
Remove the Bluetooth dongle from the USB port and plug it into a different connection. Some USB ports fail to detect certain computer hardware. Changing the connection port fixes this.
    • 4
Install the driver on the provided driver installation CD. Without the driver, the computer is unable to detect and use the dongle. Insert the driver installation CD into the disc drive of the computer, then follow the on-screen steps to install the driver onto the system.
tip
How to Fix a Bluetooth Dongle in a computer
<p>Bluetooth devices connected to a computer system via a wireless signal, so that the desktop of annoying cables and wires to strip. Even if your computer does not have a built-in Bluetooth receiver, you can create a Bluetooth dongle, the function adds the system to connect. If the dongle is not working to resolve the situation. <br /> <p><br /> <p>1. Check the system requirements for the Bluetooth dongle. If the system does not fit all the requirements, the device will not work. The requirements for the Bluetooth dongle can be printed in the manual and packaging. You can compare that with what is running on your computer by clicking "Start" "Control Panel" and "System". This gives the computer hardware. <br /> <p><br /> <p>2. Unplug the Bluetooth dongle, restart the computer, plug it into a USB port. If you leave power on the computer with the dongle already instead, the system can not detect the devices. Restart the computer and perform this action helps to correct the problem. <br /> <p><br /> <p>3. Remove the dongle from the USB port and plug it into another compound. Some USB ports do not meet certain computer hardware detection. Changing the connection port fixes this. <br /> <p><br /> <p>4. Install the driver on the included CD driver installation. Without the driver, the computer can not detect and use the dongle. Insert the installation CD driver on your computer and follow the steps on screen to install the driver on the system. <br />
on Jun 26, 2011 • Computers & Internet
Dongle for origins digitizing software won't work
I have Organs but no dongle where can I buy one.Or could you use other dongle with it or what can I do.
Bought dongle E173 works on dell computer Xpworks on laptop windows 7 but wont install on PC Specialist windows XP why ????
Hi there! If the E173 worked with your windows 7 then that means the E173 is working properly, try to check first if the PC specialist windows XP computer can detect the dongle if not then try to use a different USB port now if is detected but won't install try to find it in the drive go to my computer then look for the removable disk or the e173 then manually install it but if after trying different USB ports and the dongle is still not being detected then check if it is compatible with that computer or you can try to use another USB device to check if the ports are working properly.
Hope this helps!
I HAVE A NEW COMPUTER AND MY GIGA WARE MOUSE DOESN'T WORK, I DON'T HAVE THE PROGRAM ANYMORE HOW DO I GET IT TO WORK?
Most all mice are simple USB devices as far as most Operating System are concerned and a manufacturer supplied driver should not be necessary.
Do other USB devices work on your computer? Have you tried unplugging the wireless USB dongle that goes to the mouse and plugging it back in? Another option might be to unplug the wireless USB dongle, turn off your computer, wait 2 minutes, turn on your computer, wait until your Operating System loads fully and you are logged in, plug in the wireless USB dongle.
Also try changing the batteries in the mouse. Try another USB port for the wireless USB dongle. Other than that, it might be dead. You can call RadioShack for assistance if that does not pan out for you: 1-800-843-7422
Wireless connectivity is it possible on the EL1352G
Greetings - Looking at the specs of the machine at the E-Machines website it doesn't appear to have any internal slots for a WiFi card upgrade.
However, there are plenty of USB ports available and an inexpensive USB WiFi dongle ($15-20 USD) would work just fine. Doesn't matter which one, as long as it has drivers for Windows 7 (which would be any recent USB WiFi hardware).
Regards and thanks for using Fix Ya.
Mikeywaf
2answers
What is Bluetooth Dongle?
Hi message4,
Welcome to FixYa! How are you doing?
Bluetooth Dongle is often refer to USB Bluetooth Adapter, it is a device which you connect to your computer via USB port to allow data transfer from your PC or Laptop to Car Kits, Mobile Phones, PDAs, GPS Receivers and much more.
Hope that helps. Thank you for using FixYa.
4answers
I have bought a wireless ps3 guitar ( KRAMMER) which is a red octane and i cannot find a usb port on it ??? please help
It's actually hidden inside the guitar neck....well it is for the warriors of Rock guitar for PS3. I have one of these but no dongle so if anyone has one please let me know.ee96b211-8ef1-4fdd-9c2a-202ece6747f3.jpg16319844579014752486403742228714-zkt5tkphum4ofoiikpxk5o2c-6-2.jpg
And this is an adapter for PS3 which allows the console to receive wireless signal from wireless guitar. I have 5 guitar hero guitars so before anyone nitpicks I am aware that this wireless dongle is for my Kramer Striker guitars. I have 2 working wireless receivers and am willing to swap if someone has a wireless USB dongle for a PS3 warriors of Rock guitar. Not the triangular shaped one but the little one which is identical to Skylanders Portal USB. The one which is hidden inside the neck which I included photo of above. Thanks
I hahe usb dongle i placed it but computer does not recognise it
Try placing the dongle into another USB port; sometimes one can die and nothing will be recognized in that port. The dongle may also be dead-on-arrival, try placing it in another computer with a known good USB port and see if it's recognized. If it isn't you can try returning it to the store you bought it at saying it is dead.
If that does not work try looking on the manufacturers website for drivers for your Operating System. If you are having trouble finding a driver and changing the USB port does not work, please respond back with more details such as the dongles model and your Operating System so someone can help you find the drivers.
Hope this helps, and thank you for using FixYa.
Chartreuse,
2answers
Parallel dongle will not work with new system that only has USB connections
The dongle only works with a standard parallel port, not a USB parallel port adapter, It may be possible that a PCI parallel adapter card will work with the dongle. Check it first with the supplier and or software supplier of Designer 1.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
