I'm getting an error that states "invalid DIM"
SOURCE: Error: Invalid Dim
this happened to me as well. i looked it up and heres what i found:
http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot"
one of them is turned on so press enter and select OFF. this should fix the problem!
SOURCE: error :invalid DIM
This is my first post on this site, but I've had friends at school ask me about this. Apparently I'm like a calculator genius or something...
One solution I know of is clearing the RAM. Sounds strange, doesn't it? But it fixed three different calcs.
Be sure to back up or archive important data before doing this.
SOURCE: INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
SOURCE: Im getting an err: invalid dim on my
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
SOURCE: TI 83 ERR: INVALID DIM
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
