Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Can you try another source on the that same HDMI input ? I would like to see if this is the TV that is not working properly or the cable box. You can also try to hook up the cable box to the TV with component cables instead of the HDMI cable. The component cables are the red/green/blue colored cables. You will also need to add another cable to send audio to your TV. Component cables are just as good as an HDMI cable. HDMI is needed to display 1080p and blu-ray is the only 1080p video source thats is currently out right now so if your not using a blu-ray player, then you really don't need to use an HDMI cable. I bet that your TV will look as good or even better with a component cable.
The cable box is hooked up with HDMI cable. When the screen goes green there is no picture, just blank green screen.
Thanks
Thanks will connect using the component cables.
