Question about HP Compaq nx7010 Notebook
EMachines T1840 mother board crash
Hello guys i have a emachine T1840 the mother board crash the hard drive still in very good conditions. if i use this hard drive with a different board would it boot up correctly?. if not is there a way i can do this because i have programs that i dont wan to loose.
  • Anonymous Mar 17, 2009
    BartPE work like a charm. thank you I really appreciate that.
    Master:
  • 404 Answers
If its the same model yes it will work, if not then depends its got to to be the same bios, same chip and same chipset.
Posted on Mar 14, 2009
    Scholar:
  • 93 Answers
You need to get hold of a boot CD - BartPE is great for this. Put the hard drive in another computer, and you'll find it more than likely blue screens, as the Drive Controller Drivers don't match the motherboard. Run a program called FIX-IDE, reboot, and it should at least boot. You might find that all sorts of other bits don't work though, but your apps should. Download the drivers for the new board and you should be off and away.
6ya staff
SOURCE:
My computer has no signal
Hello, Sounds like you don't have the right power supply, only and emachine power supply from emachines will work.
Feb 22, 2014 | E-Machines eMachines Desktop PC
Windows 7 StartupRepairOffline
hi
there can be a few reasons
the motherboard can be faulty
or the hard drive could be faulty
to test if its the mother board or hard drive attach another hard drive and re-install if it works its the hard drive if it wont or cant install its the mother board
cheers
Nov 09, 2013 | E-Machines eMachines Desktop PC
I have a Emachine desktop T6216 computer, that when i turn it on the fan comes on for about 5 seconds shuts off and power-up. Now when i turn it on the fan just runs and it doesn't power-up orupload
It is possible that the hard drive has crashed. If the power supply starts up but nothing else then it is either the mother board or the hard drive. If you take off the case and the CPU fan is spinning, then it is likely the hard drive. Your best bet is to take it into a shop if you are not comfortable with swapping out the hard drive.
Oct 15, 2009 | Computers & Internet
Emachine T1840 the hard drive WD400 40GB problem Ask me to Format
try this software it is free to try and then if you see it recovered your data you can buy it in order to actually save it off...
http://www.runtime.org/gdbnt.zip
Hope this helps
Jul 10, 2009 | Computers & Internet
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Hard Drive
You can replace it with a larger one, just make sure you buy the proper hard drive. If its and IDE hard drive, buy and IDE hard drive, if its an SATA Hard drive, buy an SATA Hard drive. also make sure after you install the new hard drive that you use the operating system cd to format the drive and to install the operating system.
May 04, 2009 | E-Machines T1840 CELERON 1.8 GHz 128 MB 40...
Emachine cant find operating system
If it doesn't show a HD in bios, that means that either the HD isn't connected properly ie you have 2 devices set as slave or master on same ide cable and it cant detect the HD. Try temporarily disconnecting the CDroms or other devices that may be conflicting and see if that helps.
Hope that helps. Please remember to rate this information.
Thanks
May 03, 2009 | Computers & Internet
EMachine T1840 Restore
check the ram and hard drives.check if the os properly installed.u
Aug 31, 2008 | E-Machines -T1840-CELERON-1.8GHz,40GB...
EMachine T3025/Best Buy
get simple windows xp you just have to format deep with emachines as ntfs ive ran windows complete programs on emachines with out a problem and created straight recovery disk simple to be ran in windows safemode
now your hard drive
depending on which brand hard drive you have there is a couple out there that have data compression problems over 80 gig these harddrives over 80 gig have a crash ratio of 8 to 1 sea gate about 2 years ago had this problem dont know if they corrected it yet
quite possible your hard drive did not die at all but the power supply just didnt have the juice to push it check hdd by another source of power
May 12, 2008 | Computers & Internet
Ihave a emachines modelT2792 and have een told the mother board is no good as well as the power supplycan i get another mother board for this computer or is it too old to fix it is about 2 years old
when all some other parts are good maybe you can replace the the mother board and the power supply.
you should find motherboard replacement that will fit to your processor and Memory.
if the memory , processor, hard drive are good, then you can contact your vendor if the have replacement(mother board) and power supply.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 15, 2008 | Computers & Internet
HP Compaq nx7010 Notebook Logo
237 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
