Print Head Alignment For Canon printer For more details visit this website:
https://www.errorsdoc.com/canon/
Open the printer driver setup window.
Click Custom Settings on the Maintenance tab.
The Custom Settings dialog box opens.
Switch head alignment to manual.
Check the Align heads manually check box.
Apply the settings.
Click OK and when the confirmation message appears, click OK.
Click Print Head Alignment on the Maintenance tab.
The Start Print Head Alignment dialog box opens.
Load paper in the machine.
Load three sheets of A4 size or Letter size plain paper into the rear tray.
Execute head alignment.
Make sure that the machine is on and click Align Print Head.
Follow the instruction in the message.
Check the printed pattern.
Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
When you have entered all the necessary values, click OK.
Note:
If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
(A) Least noticeable vertical streaks
(B) Most noticeable vertical streaks
If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
(A) Least noticeable horizontal streaks
(B) Most noticeable horizontal streaks
Confirm the displayed message and click OK.
The second pattern is printed.
Note:
The third pattern is printed.
Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
There are only 2 letters, db
maybe you are receiving a file attachment that your computer dnt have the application software..pls let me know what is the last 3 letter of the file from attachment so that i can tell you which program to use to open the attachment
