Computers & Internet Logo
Anonymous Posted on Apr 29, 2013
Samsung mobile s3310
My mobile is samsung s3310 it 2 days before it went offlike it restarts in every 1 min and the battery is going off soon and also the mobile is so hot. What to do have solution to get the device working
Battery completely drained after 45 mins of listening to cd player without car running,
a healthy battery will take a charge and discharge and be o k -you have several things going on-the ticking noise is some kinda rely that is turning on and off probably because of low voltage-the voltage jumping around sound like the alternator is giving up and is not fully charging battery-you may also have a drain on the battery that doesn't stop when you turn the key off like an extra power amp for the radio- you can take your car to autozone or advanced auto and they will check out the charging system for free and tell you what is going on-cheers Denny
1helpful
My cell c5-00 now from yesterday problem that mobile itself restart within 2-2 min...and like problem that listening music the song run 2 min then itself mobile restart so not doing any work also call same...
There is Software Problem of your mobile or There may be virus attack on your mobile so it is getting restart after 2 min. You should renew your mobile software if your a technician the use the dongle box to renew your software like JAF Software Dongle or UFS software Dongle using this you can renew you mobile software if you are using any other software dongle's then you can use that to renew your mobile software.
After doing this if problem does not solve then there is hardware problem in your mobile please check the battery connector, power amplifier, Power IC & Boot IC. while doing this your mobile will get damaged so do it very carefully if your mobile go dead then we are not responsible for that.
If your are not then Please visit your nearest Nokia Service Center (Nokia Care) or Visit any Mobile Repair Center they will solve your problem in a day.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
7helpful
4answers
Hi I Cant Find A Free Sim Unlock Code For A Samsung Sgh J700i Could You Help Me?
1- Power on phone, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your phone should restart after 1 min,
now, and before it restarts, push your sim card in, without removing battery.
4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now , Enjoy
6- now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
N73 mobile is Switching off after one or two calls & light sensor is bot blinking. Battery is full charged after listing two to three songs, mobile get Switched Off. when we connect to charge the...
The Happy news is your phone is perfectly working.Only the battery is the problem.Your Battery is stone dead.That is it will get charged(Acting like it is charging).If you use your mobile the charge will go off soon.Is you battery is bulged?See any slight bulge in the bodPlease do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-) y of the phone..Replace the battery soon...
Car will not stay on after I JUMP START
Just try to keep the gas and drive for at leat 15 min HWY if possible. Yes, it will turn off if you let go the gas, but it will restart and stay on as long as you press on gas. Just keep on driving and the computer will readjust the emission inputs and will get back to normal.
Truck wont restart when it's ran for greater than 5 min.
Will it restart warm if you hold the accelerator to the floor?
Blackberry camera
turn off ur bb mobile by disconnection the battery from mobile phone and put the battery after 1 min and start the hand set
Samsung soul u900, had phone for 1 day, bought 2nd hand, twice it restarts itself if not used, is this normal
hi snickbo,
               if u keep ur mobile in a pouch, which has any magnet buttons means, this problem is very common... even if its not the case, samsung mobiles sometiimes restarts like this...so u need not worry about this
        good luck,
        trendsetter
2answers
Phone is restarting
try a new battery
Feb 14, 2007 • Nokia 6100
Grand Canyon Tech
Grand Canyon Tech
