This lasts about 10-15 minutes; the longer it's been off, the longer it takes to settle down. It's been getting worse, though, and now spurts of wobbly, horizontal lines blur the picture sporadically. It's very frustrating and quite worrisome for a home w/3 boys on spring break who love to watch TV and play Wii!
SOURCE: Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
SOURCE: Mitsubishi VS-50707 shuts down sporadically
what if the pic doesnt stay on long enough to run the test? Mine doesn't stay on more then 15 seconds before it powers off. This happens everytime now.
HELP and THANKS
SOURCE: Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set
can be a cause of mischief; please move it further away and see if that
helps clear up the problem. But, you must keep it away for several
days before you will know for sure because it takes some time to
degauss all the internal parts that may have become corrupted by the
magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom.
Old sets are sometimes not worthy of the repair simply because of the
likelyhood that another failure will follow soon after. A big screen
always invokes a repair charge of $200 and up. After a few of these you
will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking
circuits of the set. These are horizontal retrace lines that are
supposed to be blanked out during vertical retrace of the raster.
Think of it as a paintbrush that scans across the screen painting thin
lines and when you get to the bottom of the screen it goes quickly back
to the top, but during that time the horizontal, which is many times
faster, has made several sweeps; so it must be blanked out during the
retrace. The repair involves finding the guilty parts and replacing
them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if
that will recover any of the circuit degradations. Merely unplug the
power cord and leave unplugged for 4 hours or more. It may help. Or,
it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate
for any expensive repair. On the other hand, it is a Toshiba - and
they make a fine set.
Hope this helps. Let me know if you have further thoughts.
SOURCE: VS-50705 50" rear projection TV does not
Hi is most robably that you are having a issue with the power supply.
