During spin cycle washer made a really load noise like something banging on inside of cabinet stopped cycle & redistributed clothes still sounds like really off balance with a lot of banging noise
Old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The
bellows is a rubber sleeve that seals the suspended outer tub to the stationary
cabinet front at the tub opening. Its purpose is to provide a water tight
opening into the tub that can be sealed by the cabinet door, yet allow
flexibility for the oscillation of the tub during the wash and spin cycles. Outer
Tub Assembly
The
outer tub assembly is supported by two suspension springs and stabilized by two
air shock assemblies. A cement counter weight is mounted to the front of the
outer tub by screws. A counterweight is molded into the rear half of the outer
tub. These counterweights prevent excessive oscillation of the entire suspended
assembly during an unbalanced spin cycle. Spin
Basket Assembly
The
spin basket is constructed of stainless steel. The circumference of the basket
is perforated to allow water to flow through it as it revolves. A heavy steel
shaft is pressed into the spin basket support which is then bolted to the
basket. The spin basket assembly is entirely supported by two ball bearings
pressed into the rear of the outer tub. A large drive pulley is mounted to the
free end of the shaft that extends through the rear of the outer tub. There are
three plastic vanes mounted to the spin basket to aid in the washing action
during the wash cycle. The rotation of the spin basket provides both the
washing action during the wash cycle, and water extraction during the spin
cycle.
High pitch "jet engine" noise--A certain
amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in
drum or pump. Stop washer and check drum. If noise continues after washer is
restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To
prevent unnecessary noise and damage to drum, fasten fasteners and turn items
inside out.
Squealing sound or hot rubber odor-- Washer is
overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a
thumping sound. This is usually normal. If sound continues, washer is probably
out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it
rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer
is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for
details.
• Shipping bolts and foam blocks have not been removed
during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts
and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and
rearrange wash load.
Please do rate the solution and revert for further assistance.
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Washer tub out of balance during spin cycle
