RIM BlackBerry  Pearl  8100 Logo
Posted on Mar 14, 2009
Blackberry pearl cap locks stuck
Awesome site, gave me the solution I needed which was to press the two lower left keys together. I had tried everything else including removing the battery, I can use predictive text again whooo hooo
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
911
Points
5
Try holding the key on the left that looks like an arrow. While holding this key hit LGLG. Then change the warning portion to debugging. hit the menu key to erase the log.
Unlock blackbebrry pearl 8100
Hi, You can unlock a Blackberry Pearl 8100 safer and easier using unlock code. You can get the unlock code for a Blackberry Pearl 8100 from www.superunlockcodes.com/blackberry-pearl-8100/rs12wp9/ at affordable cost.
UNLOCKING STEPS FOR BLACKBERRY PEARL 8100
1 - Switch ON your Blackberry Pearl 8100 with your current network/service provider's SIM card,
2 - Go to Options Menu => Advanced Options,
3 - In the SIM Card menu, hold down the Shift (right of the zero, cap) press meppd, (NOTE: You may not see any text appear on the screen while typing meppd)
4 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2, (NOTE: You may not see any text appear on the screen while typing mepp2)
5 - Enter the unlock code.
I can't get my phone off CAP or NUM
Hi, To turn NUM lock on, hold the *Shift* key and press the *Alt* key. · To turn NUM lock off, press the *Alt* key.Hope this information is helpfull
When sitting idle, my pearl lights up randomly. i
Try this Hold down the ALT key, and press right-hand CAP key press the DELETE key aswell together which resets the blackberry
Have you installed any new application?. Bcoz this is happens due to new application (themes).Please delete the particular application and check.
2answers
Screen is white with black line, will not reboot.
Hold down the ALT key, and press right-hand CAP key press the DELETE key aswell together which resets the Blackberry Mean while try conecting your Blackberry to computer using data cable and check computer is recognising the device, If not you need to go to service centre
2answers
I dropped my black berry 8100 pearl and now it wont turn on, the red light will come on half way then full, but it still wont turn on.
This might be the Hardware issue you need to walk into the service center to check the hardware of your Handheld.
Thank you for using Fixya.
I cannot type, or click my trackball! I can scroll, but thats it!
just reset the device and chill. see that no key is left pressed accidently
1helpful
3answers
Blackberry pearl wont except sim card
How To Enter the Unlock Codes on a BlackBerry Cell Phone
Model : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked
2answers
How to unlock a blackberry
BlackBerry Pearl 8100 Can be done without a sim card inserted To Unlock:
while typing )
I want to lock my Samsung t319 phone when it's on
Try pressing the menu left key button and then asterisk button, normally that should lock it then you can unlock it pressing the same key, repl back if that didnt work
63helpful
8answers
Caps lock
Open up an email, or something else you can type into. Click the menu button, and select "enable multitap." Then go back to the menu and select "enable suretype." That took off the cap lock for me. I just wish I knew how it turned itself on to begin with!
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
