Help! my ipod shuffle 1st generation, 1G is not working at all! no lights, no sounds and when i plug it in usb drivers it says that unknown device! pls help me!!!
Betty, Check the attached links, iPod 1
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
On October 26, 2006, Apple released an iPod Shuffle Reset Utility that corrected this problem for some owners of first-generation iPod Shuffles Then, in March 2007, an updated iPod Reset Utility was released which can also address similar problems with second-generation iPod Shuffles.
Good luck, I hope this helped
Please rate me
The iPod reset utility will reset your iPod shuffle back to it's factory settings. It works for the following shuffles: iPod shuffle (1st Generation) - iPod Software version 1.1.5, iPod shuffle (2nd Generation) - iPod Software version 1.0.3 The reset utility will fix the following issues. 1. The iPod won't play music and can't be restored using iTunes 2. iTunes won't see the iPod but you can see it under "My Computer" in windows or under Apple System Profiler on a Mac. 3. iPod shuffle (1st Generation) is identified as a device in "Recovery mode." iPod shuffle (2nd Generation) is identified as a "USB DFU device."
You have to have administrator privileges to run the restore software and it will wipe out all the information on the iPod (including all your music) and install factory software back onto it. System requirements are Mac OS X 10.3.9, or later, Win2k with sp4, Win XP, this won't work on Vista. Download the file for the program here: MAC http://www.apple.com/support/downloads/ipodresetutility102formac.html Windows http://www.apple.com/support/downloads/ipodresetutility102forwindows.html
Install the software onto your computer, plug your iPod into the USB port and run the reset program, it will ask for your permission to reset the iPod, answer yes and the process will proceed. After finishing the reset procedure then use iTunes or whatever software is used to access your iPod and load your music. Enjoy your toy!
if you have itunes loaded already on your pc then try plugging the ipod into a different usb port to the one you have already tried. Hopefully it will be picked up.
I am not sure about the 1st generation but the 2nd generation definitely charges via the USB connection. If you don't hear the music its because there are no songs on your device. When you initially add songs, they go to the Library in iTunes, not the Shuffle. Just drag and drop your songs from the "Library" to your "Device" in iTunes and then you'll notice them get sync'd with the Shuffle.
there's no light at all..
when i plug it it says ''device unknown''
what should i do?
