Question about Microsoft Windows XP Professional
Folder Options is removed from Tools in Windows by a virus. The virus is called W32.Rontokbro@mm OR W32/Rontokbro.gen@MM
The removal of this virus is slightly difficult. Antivirus can't remove
it automatically. However detailed procedure to remove it is available
at
http://coolexp.blogspot.com/2008/01/fold...
About this Virus/Worm:
What it does is creating new files which looked like a folder but its
actually a .exe file. Unless you’ve enabled the view extensions in the
folder options or else you won’t see the .exe extension of the file.
The file is approximately 43.7Kb and normally people will click to open
it because it looked like a folder. So after you’ve open it, the virus
will run each time during startup and keep on spreading and spreading…
into the harddrives.
More troubles coming up. Normally when you click “Tools” in explorer,
there’s a “folder options” underneath it. Once the pc is infected with
the virus, the Folder Options will be missing, which disabled you to
change the options to view the extension of the files. So when you see
a new folder appeared from nowhere and you clicked to open it out of
curiousity, the virus spread more again. Moreover, the virus disabled
the registry edit where you will see this message “Registry edit is
disabled by the administrator” everytime you try to edit the registry.
So how to clean the virus then? I found some solution from the following link and have successfully cleaned it from my system.
It will help you to get rid of this virus named W32.Rontokbro@mm aka brontok.a and to get back your hidden files.
Source(s):
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 14, 2009
Or Try to use command prompt:
Let's say you want to see all hidden stuff inside the D:\Temp folder. Check the steps below:
1. Go to Start >> Run. Type cmd and press Enter to open the command prompt.
2. Now navigate to the directory from the command prompt.
[For
eg. Assume you are in C:\Documents and Setting\Jose. and you want to go
to D:\Temp; type D: and press enter. This will take you the root D:\ in
the command prompt. Type cd Temp in the command prompt and press Enter. Now you'll be inside D:/Temp from the command prompt.]
3. Type the command dir/ah to list all the files under D:\Temp.
Once you get the name of the files, you can view or run them by entering the file path in the address bar of Windows (The address bar of Windows is similar to the address bar of Internet Explorer, where you type the website or folder address).
To delete files use the del [Folder Name] in the command prompt. This will delete the folder you specify under the current directory. Eg del Temp
Oct 22, 2012 | Microsoft Windows XP Professional With...
on Jun 03, 2010 | Computers & Internet
on Apr 28, 2010 | Computers & Internet
Dec 06, 2011 | Dell Computers & Internet
Feb 15, 2011 | Microsoft Windows Vista Business with...
Aug 25, 2010 | Computers & Internet
Jun 14, 2010 | Microsoft Windows XP Professional SP2
Jan 08, 2009 | Computers & Internet
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
Jun 17, 2008 | Computers & Internet
Mar 05, 2014 | Microsoft Windows XP Professional
Feb 19, 2014 | Microsoft Windows XP Professional
Feb 17, 2014 | Microsoft Windows XP Professional
291 people viewed this question
