Our door hinge is broke on Bosch Axxis+ Front loader. We are still able to use it, but just about every other time we open the door, it falls completly off. It looks like if we could just find the plastic part of the inside the door to replace, it would be fine. Any suggestions on finding parts or what our options are would be appreicated. Thanks
There are 4 screws in the door that hold a plastic hinge cover on
.The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
The door is heavy...
I am quite surprised NOT TO SEE a help video...
but the part I found is not terribly expensive...
http://www.appliancepartspros.com/bosch-door-hinge-171269-ap2822727.html
It has been a long time since I have recommended
SEARS... (but lately they have been upping assistance
and competing (price-wise))...
Use caution at SEARSPARTSDIRECT
Water Filters Lawn Garden Appliance Parts
Hope this helps
Carnac the Magnificent
SOURCE: water wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
SOURCE: Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
SOURCE: Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
