SOURCE: kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
SOURCE: I have a Kingston Data Traveler 2GB USB Flash
Hi there, some time its happens because of the drivers. I give you a suggestion that, change the USB connector & use other one. If the same thing happened then install the USB driver again from the drivers disk. Then restart your computer and try to use that device. If again you face problem, then visit the shop & ask the person for check the Device. I guess your device have a problem. Because you also mentioned that, your already try these in other computer & face the same problem. You have one year warranty so you can get a new one from the shop.
Thanks & waiting for your feedback.
SOURCE: MY KINGSTON 8GB DATA TRAVELER
There is a switch on the side of the card, Flip it one way and it's locked and write protected and the other way is unlocked.
SOURCE: USB Device Not Recognized in winxp(kingstone 2GB USB2.0 DATA TRAV
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a reply
hope this helps you
SOURCE: Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
hope this helps
